I'm trying to figure out how to update the url of a hosted feature layer in AGOL that is shared on Open Data. The feature layer was originally published thru ArcMap to AGOL but I now would like to update the url with a service from our ArcGIS Server. When I look in the settings options for the hosted feature layer I don't see the option to update the url like I do with other items. I've also tried to update the registered service url using the ArcGIS Online Assistant. It lets me add in the url but when I click update and check the url it reverts back to the hosted AGOL url.
I believe because the data was originally uploaded thru ArcMap that I may need to overwrite the service thru ArcMap but I'm a bit confused on how I would now point the AGOL url to that of our ArcGIS Service url thru ArcMap. I would rather not completely remove the item from AGOL and have to re-populate all the descriptions and settings in Open Data since this is pretty time intensive and doesn't seem like it should be necessary.
Hopefully there is an easy solution I am missing.
Thanks in advance,
Kathy
