Unique Symbology on ArcGIS.com Map
1007
11-16-2011 11:21 AM
StephanieWidas
I have created a map on ArcGIS.com and am using Unique Symbols.  In my legend, "others" always appears below the symbols that I set up for the layer.  Does anyone know if there is a way to turn this off and just show the symbology that I defined?  I have attached a screen shot illustrating this.
Thanks!
Stephanie
MikeMinami
Esri Notable Contributor
There is no way to turn that off at this time. This will be addressed in an upcoming release in December. Basically, if a layer is editable, then this is a catch-all category for features that are not one of the specified types. We'll allow you to disable editing on a layer and you won't see this entry in the legend. However, if you enable editing, you'll still see it.
Mike
StephanieWidas
Mike,
Thank you for your prompt response.  We're looking forward to the ability to turn that off in the legend.
Thanks again,
Stephanie
RupertEssinger
Esri Alum
To prevent the 'Other values' class appearing, open your web map in ArcGIS Explorer Online and do the symbolization there instead of in the ArcGIS.com map viewer. The 'Other values' class won't appear in the legend when the map is viewed in either client.
