Unable to open AGOL hosted feature layer attribute table in Pro
801
05-06-2024 12:25 PM
ZenMasterZeke
I have a point feature layer in AGOL created from Survey123 Connect. Surveys are collected with the S123 Field app. I can add the layer to a map in ArcGIS Pro, and the points display, but I'm unable to open the attribute table or popups. The error message says 'Failed to load data. Error: Unknown Error'. While the error message displays, an empty attribute table is visible, with 4 rows (correct number), but when I click Ok on the error message the table also disappears. The table is visible in AGOL web maps.
I've republished the survey, looked at the schema, etc. Any ideas what the cause is and how to fix it? Thanks.
