Unable to Edit Map Tour Category Items
528
04-29-2026 10:59 AM
SBBIntern
Hello,
I am using a Map Tour for the first time in my StoryMap that I am creating. It is a Grid Categorized tour and I want to be able to write a description within each individual item, but it will not let me.
For example, I have the towns in my county separated into 3 separate categories, "A", "B", and "C", but I want to write a description for each town, attach URLs, attach media, etc.  but I can't even type even though I was able to before. I'm looking for a solution to this, maybe I made the feature layer incorrectly? Do I have to write the description within the table of the feature layer? This is my first time posting here so any assistance is greatly appreciated!
Thank you, Madyson
2 Solutions
Laura
by MVP Regular Contributor
Description is coming from a field in your data. You can then go to the media tab to play around with attachments.
If you want to customize it more and write your own descriptions I would use a side car rather than a map tour.
Laura
You can add a text field and include a link for media or just enable attachments on your layer.
Laura
SBBIntern
Thank you for your help, I was able to add the description field for now, I'm hoping I'll be able to write more in the future but that is something I will fiddle with later. As for adding in media, will I have to make a new Media field in the table, and then just attach links to the photos I want to add in? I'm not sure hoe to configure that since when I go to add a new field, my only options are String, Number, Date, or Global Identifier.
As for using the Side Car v. Map Tour, I am looking ability to toggle between the different places and allow users to compare what it says for their town versus another. The project I am working on is evaluating townships, so to be able to separate them by categories and for easy navigation between towns is vital .
Laura
