Unable to change symbol on one layer in a web map
5003
12-09-2014 04:19 AM
PeteCrosier
Has anyone experienced the inability to change symbol on one layer in a web map, whilst it works on the rest / others?
I have a point layer that doesn't do anything when I go to Change Symbols - Option - Change Symbol, but in the Chrome logs I can see some error messages which don't happen on the other layers in my map (including other point layers).
The log is:
arcgisonline.js:2615 Uncaught TypeError: Cannot read property 'color' of undefined
arcgisonline.js:2615 b.declare.updateUI
arcgisonline.js:2610 b.declare.init
arcgisonline.js:7075 b.declare.showSymbol
arcgisonline.js:4182 b.declare._onSimpleChangeSymbolClick
dojo.js:176 (anonymous function)
dojo.js:243 g.(anonymous function).h
base.js:98 b.onItemClick
base.js:93 (anonymous function)
dojo.js:219 (anonymous function)
.. any clues? Thanks.
Reynaldde_Castro
Did you add the layer individually by specifying the layerId rather than the entire map service? This should give you the option to change the symbology.
ChayaBalsiger
I was having the same problem as Pete and I tried this and it worked for me...thanks!
XanderBakker
Esri Esteemed Contributor
Try removing the layer and adding it again.
PaulLohr
Pete, did you get this resolved?
MikeDavis5
I am having the same problem. I tried removing and adding the layer, but that didn't change the options -- no "change symbol."
