Turn off pop-ups for features not shown on web map
3569
10
06-24-2019 09:07 AM
MinnesotaDesign_Center
Is there a way to disable pop-ups for features that aren't visible on a web map? I have a master assets layer that I'd like to be able to reference on a series of maps tailored to show different categories. Using unique symbols, I'm able to show only relevant categories while grouping the other, unneeded features into the "Other" label. This works fine as far as the symbols go, but I'm left with phantom pop-ups appearing even though their corresponding features aren't visible. I know I can just make copies of the master layer and delete unneeded features from the copies if necessary, but it seems like there should be a better way.
Spike73
Hi Kelly,
I'm experiencing the same popup behaviour on points filtered with 'Display filter' (set in ArcGIS Pro and then publish the layer). Was this bug solved? I couldn't find any logged bug about this issue.
@MinnesotaDesign_Center, did you find a way to solve your issue?
