Thematic Maps Using AGOL
527
05-14-2020 05:59 AM
RobinDiSalvo1
Is there a way to make a thematic map using AGOL?  Similar to the one attached using the zip code boundaries
Egge-Jan_Pollé
MVP Regular Contributor
Hi Robin DiSalvo,
Yes, you can! See screen captures attached.
In the Map Viewer, under your layer, click the button Change Style. In the Change Style dialog
  1. Choose an attribute to show
  2. Select a drawing style
... and you're done!
HTH,
Egge-Jan
RobinDiSalvo1
I am working with shapefiles and for some reason it does not show the option "Shape_Area"  under #1 Choose an attribute to show.  Do I need to use a different type of file?  Excel or CVS in order to create a thematic map?
Appreciate your help on this!
Robin
Egge-Jan_Pollé
Hi Robin DiSalvo,
Oh sorry, I just used 'Shape_Area' as an example. In your case you should just choose the relevant column from your attribute data, i.e. the one containing the Percent of Total Permits Issued.
HTH,
Egge-Jan
RobinDiSalvo1
Thank you!
