Symbology - Other values cannot be expanded anymore
307
07-11-2025 07:21 AM
KFunahashi_SSMMA
I used to be able to expand all the values in the "Other" by clicking like these double-arrows.  Those aren't there anymore.  I can't click and drag the values out of "Other".  What do I do?
RussRoberts
Esri Notable Contributor
When you select the values in Other you should see this action pad which lets you pick which grouping you want to place those values in or you can create a new group from that selection. The overflow menu would only have the option to do a select all.
Once the values are outside the Other category you can use the arrows to move them up/down
