Symbology in legend is not displaying correctly.
4758
11-16-2015 03:51 PM
RandallClark2
So i finally figured out out to configure the print tools with my ArcGIS online map but when I print my map the symbology for the features is not displaying correctly.
Any thoughts?
Pleade ignore the obvious errors, like the mispelling landscape i am aware of it.
DanPatterson_Retired
landscaping is spelled wrong...
no clue what MSW means...
your title ?
RandallClark2
i am aware of that thank you.
MSW = Municipal solid waste.
the title is a work in progress.
now back to my question any idea on why the symbology is messed up?
Not sure, but I found this link reporting  printing problems to pdf.  If you look at the legend, it is pretty bad, perhaps a similar issue. Printing to pdf returns a legend with striped symbology (look at the map in the main thread)
I search GeoNet using .... ArcGIS online print problems ... and there were more that I didn't investigate since I wasn't sure whether the printing was direct or from output.  (title is much better)
RandallClark2
yeah it was very juvenile. Thanks for the links i will check them out!
