Symbology changes in ArcGIS Online map viewer for no known reason
648
11-06-2013 06:59 AM
GunnarOlson
I created a web map containing a parcel feature service. In the ArcGIS.com map viewer, I set the symbology for the parcels to white outline with no fill (100% transparent fill). Then, I opened the map in ArcGIS Explorer Online, zoomed to a different extent, and saved the map. When I open the map in the ArcGIS.com map viewer again, my parcel symbology is changed...0% transparent fill...so they're all black! Symbology is fine when I open up map again in ArcGIS Explorer Online. What's up with that!? I've tried this several times with the same results...
Any help would be great.
by Anonymous User
Not applicable
Hi Gunner,
It's hard to say, but it could be a legacy issue with Explorer Online which is in mature support. Is there a workflow you're trying to accomplish in Explorer that cannot be done in the ArcGIS.com Map Viewer?
Cheers,
Andrew
