Support for CSV with föreign letters (äöå) when using ArcGIS Online's add file option
4249
8
05-18-2012 02:50 AM
LilianaDiaz
I've used ArcGIS Online for some time now and it has worked very good for CSV files with foreign letters. I usually drag and drop the file to the map without any problem perserving my Swedish letters (öäå).
I'm now using AGOL subscription to add a CSV file with more than 1000 points. When I add the CSV file using the menu: Add --> Add layer from file I lost my Swedish characters.
First I thought was a problem of ArcGIS Online for organizations, but now I have tested that it also occurs in ArcGIS.com. If I add to the map the same CSV file via the menu I lost my Swedish characters.
Is there a workaround to this? I need to publish a CSV file with more than 1000 points and keep my foreign letters.
Can be this a little problem that needs to be fixed in the ArcGIS Online cloud? Perhaps review what the menu does to the files? or looking into support for international letters?
Thank you ver much for your prompt answer.
/Liliana
PS. Attach a print screen of the result of adding the same CSV file via the Add menu and the drag&drop method.
by Anonymous User
Not applicable
Original User: mikem
Seems like Excel may have a problem? I tried downloading your original spreadsheet and saving it as CSV from Excel using UTF8, but it didn't work. So I opened the CSV in Notepad, then again saved it as UTF8 encoding and it worked...The file is attached.
Mike
by Anonymous User
Not applicable
First, let me say that your subscription will not allow you to add more points to your web map. A subscription will allow you to create a feature service that can serve up those features rather than storing them in the web map.  So, if you are able to load the 1000 features via drag-n-drop and get acceptable performance, then you are ok. The 1000 feature limit is a general guideline and will vary depending on the type of features (points, lines, polys) and the browser you are displaying the web map in.
Now, about the text coming across differently, are there addresses in your CSV file? Can you share your CSV file here?
Mike
LilianaDiaz
Hi Mike,
Thx for your prompt respond!
Sorry, by "I'm now using AGOL subscription to add a CSV file" I meant publishing a CSV file via "Add Item". It gets published as a Feature Service and that is the service I used in my webmap (see imgs).
My CSV file has X and Y coordinates and not addresses. I have also attached the CSV file I'm using (as .xlsx since I couldn't upload .csv). It contains för now test data but under Län's column I will be having information as Stockholms län, Västerås län, Lindingö stad, etc. Same thing under "kommun" (municipality) and "resultat", I will be having info med Swedish characters.
Thank you very much!
by Anonymous User
Not applicable
Liliana,
I suspect your CSV file is not stored in UTF-8 encoding. I successfully took a subset of the features in your excel file and saved them as a CSV with UTF-8 encoding (attached in ZIP format). I then published the following service:
http://www.arcgis.com/home/webmap/viewer.html?services=67d729646f3b48679631d385d2060ab4
Hope this helps,
Mike
LilianaDiaz
Hey Mike,
I really don't know what I'm doing wrong. I used your zipped file i AGOL Organizations and it worked! However, when I save my CSV file in UTF-8 unicode (see attachment) and do the same, I don't get the Swedish letters (Grrr)
How did you create your CSV in UTF-8 code?
I'm using excel, when I'm saving the file as CSV format, I select Web Options (Webbalternativ in attachment) and then Unicode.
/Liliana
by Anonymous User
Not applicable
Mike
LilianaDiaz
Hi Mike!
Japp, Excel was the problem. I tested your attached file and it worked fine but as soon as I open it in Excel and save it as CSV (in UTF-8 format) stops working.
Thank you very much for your help!
ArcGIS Online for organizations is working just fine.
Best Regards,
/Liliana
by Anonymous User
Not applicable
Original User: adcadc
This worked for me, too!
Thanks!
OscarMonell
Perfect!
To bad Excel is messing up the text encoding though! 😞
