Sporadic issue with Classic Web Maps not working in Chrome v.142.0.7444.60
2474
16
11-04-2025 07:32 AM
JackBovee
Our Chrome web browsers happened to update overnight to version 142.0.7444.60.  Now, whenever we try to access an WAB using the Classic Web Map Viewer (or any map using the Classic Web Map Viewer), none of our hosted layers are available.  Everything is visible and functional still if you open the map in the new Map Viewer, but anything build with Classic seems to be broken atm.
We still haven't finished converting all our WAB applications over to Experience Builder yet, as I had assumed they would continue to work until next spring.
cepsgis
It is. Trust me.
Jamie_Leitch_CNF
yes this solved my issue, thank you!
JackBovee
The Chrome settings were in the browser itself, just to the left of the address bar.
cepsgis
This is impacting all services in web maps consumed by our EAM solution. Dashboards, surveys, and Experience Builders are also affected, and field staff are now reporting issues accessing data.
MichaelB25
I've been working on a similar problem this afternoon. Only in updated Chrome browser several of our imagery basemaps weren't displaying. Enabling "local network access" (either from pop-up, or "site information" icon to left of URL) resolves problem.
I'm guessing that AGOL apps are referencing what Chrome sees as the local network. This is a broad list, I'm guessing a local loopback may be to blamed, but unsure. See: https://wicg.github.io/local-network-access/#non-public-ip-address-blocks
Charles_Blanchard
Hello @JackBovee,
This behaviour is due to an update in the way Chrome handles Local Network Access checks. You can read more about that update here: https://developer.chrome.com/blog/local-network-access.
For the time being, until the issue is fixed by Esri, you can utilize the following workaround. To avoid the inconvenience of having to constantly block or allow Local Network Access, you can go to chrome://flags/ and set Local Network Access Checks from Default to Disabled, which restores the behavior prior to the Chrome 142.x update.
Please feel free to reach out if you have any further questions!
Charles Blanchard
Associate GIS Analyst
Esri Canada
rgsteele-CoV
Hi Charles,
Can I please get an update on this? Our organization is seeing this issue where users accessing resources from sites on the arcgis.com domain are being prompted to allow the site to connect to devices on our local network.
We have opened a support request with ESRI only to be told that we need to create an exception to this security policy, with no further explanation provided. As a member of our organization's security team, I need to understand the rationale for your service to require this access.
Thanks!
Ryan
