Some AGOL searches not working in Web App
5497
21
07-09-2015 09:18 AM
LisaHuggins
I have some searches of feature layers that are not working in the web application.  They work fine in the web map viewer, however.
JakeSkinner
Esri Esteemed Contributor
Hi Lisa,
Can you provide more detail?  For example:
1.  What application are you using?  (i.e. Web AppBuilder, Basic Viewer, etc)
2.  What type of service are you using? (i.e. ArcGIS Online Hosted Feature Service, ArcGIS Server Map Service)
3.  What is occurring when you try to search for the feature?
4.  Are you able to provide a URL to the application?
LisaHuggins
Hi Jake.
1. I'm using Web Appbuilder
2. Services are ArcGIS Server Services
3. I get response that "no results were found for 'x'"
4. These are secure services so I'm afraid the URL won't help
Thanks for your response.  I have other applications that were built with web AppBuilder that are working.  In some of the applications, some searches still work whereas others do not.
JakeSkinner
If you press F12 on your keyboard this will open your web browser's Console.  When you perform the search, are there any error's reported there?
LisaHuggins
None that I see but I may not be looking in right spot.
LisaHuggins
So I rebuilt the searches with the new AppBuilder searches - how nice are they!?  It is working much better and returning results. Only problem now, is when I choose record I want to zoom to, the app zooms, but the popup window is empty.
Jianxia
Lisa,
We fixed some search issues. Could you give it try?
Jianxia
LisaHuggins
The search works and returns results.  However, a blank pop up comes up, even though we have popups turned on
Jianxia
If possible, can you share the service? if not, can you open the browser console and take a screen shot of the error?
Jianxia
Jianxia
Also, could you try the same map in map viewer and see if the empty popup returns?
Could you guys take a look?
Junshan Liu
Lemao Wu
ZeZheng Li
