Sketch layer sharing and save by public ?
1086
6
04-03-2022 02:42 PM
Da-WeiLiou
New Contributor III
Hi, Can anyone help me with this ?
I created and shared a web map (new map viewer) with Sketch Layers so that public can input on the map.
Now the public can use edit or sketch tool to put comments or drawing on the map.
After that, Can this "updated" (sketched) new map can be saved (or saved as) if this public without the ArcGIS Online license ?
Thanks.
David
RussRoberts
Esri Notable Contributor
Currently not. If you wanted something like that you would have a point feature and labeled off of a comment field to show the text that way.
RussRoberts
The sketch layers need to be saved to the map so the external users wont be able to persist their changes bc the layer is just saved(written) into the web map itself. A hosted feature layer should be used for this above use case you mentioned.
Da-WeiLiou
New Contributor III
Hi Russell,
Thank you so much for your help.  The editable feature layer did work OK for Point, Line, or Polygon.
How about the "Comment" (Text) ?  Is there a way for public to put text ?  Thanks a lot.
Da-Wei
RussRoberts
Da-WeiLiou
New Contributor III
Thank you so much!  This is helpful.  Da-Wei
2048tm
I got it. Thank you for the helpful post.             cupcake 2048
owlnutcracker
New Contributor II
Not now. You could use a point feature and labeled comment area to display content like that.
dumb ways to die
