Show field names in the table instead of field alias
1165
03-20-2024 01:14 PM
Lin0527
Does anyone know how to display the field name in the attribute table in ArcGIS online map viewer, instead of showing field alias? It seems that there is so such option in AGOL as turning on and off "show field alias" in ArcGIS Pro. Is it possible to achieve that by hardcoding the json file?
Many Thanks,
Lin
MikeMinami
Esri Notable Contributor
I don't believe it's possible to show the field name instead of the field alias in the table in map viewer. Is it an option to make the alias the same as the field name?
Mike
MikeMinami
Mike
