Show all features from one layerin a single spot in pop up
366
03-23-2026 07:45 AM
Labels (2)
Norquest
I saw some previous posts of people trying to do this and I figured out a way. You must be in a version of portal that has $userInput available.
I wanted to show a list of all features from a single layer in a single spot when you click on that spot. I have a layer of utilities engineering As Builts that overlap, three or four can cover a single intersection and I want users to have the choice to open any one of them when they click on an intersection.
I know users can "scroll" through features on a pop up but i wanted them all on a single pop up.
One of my fields is a URL field and this turns a field name into a hyperlinked URL
I would like help making the display either a table or bullet points.
they currently come through like:
Name 1975 Name 2003 Name 1982
also, "AsBuilt_Name" doesn't pull through
EDIT: Html "<br/>" breaks it into a new line, still could use some customization
var AB = FeatureSetByName($map, 'As Built Polygons')
var ABpoly = Intersects(AB, $userInput)
// uses the intersect of the click//
var result = ' '
for (var poly in ABpoly){
  var link = poly.AsBuilt_Link
  var name = poly.Laser_fiche_name
  var yr = poly.year
  var nm = poly.AsBuilt_Name
  result +=  nm + "   <a href =" + link + ">" + name +  "</a>" +"  " + yr +  TextFormatting.NewLine
//pulls the fields from the layer and builds a url using the field name//
return {
  type: 'text',
  text : result
KenBuja
MVP Esteemed Contributor
Here's a way to create a bulleted list.
In each loop, the string is pushed into the result array. The string also use a template literal. The Concatenate function creates a string from that array, separating the array items by a line break.
As for the AsBuilt_Name not coming through, have you checked using a console in your loop whether there's an attribute in that field?
var result = []
  var yr = poly.year
  console(nm)
  Push(result, `• ${nm}   <a href =${link}>${name}</a>  ${yr}`)
return {
  type: 'text',
  text : Concatenate(result, '<br>')
KenBuja
var result = []
  var yr = poly.year
  console(nm)
return {
  type: 'text',
Norquest
Thanks for the quick response! This added the bullet points with an indent.
The "AsBuilt_Name" field is empty in some cases and that was the issue.
and idea how to make the font bigger on these rows?
Thank you so much
KenBuja
There are several ways to do that. You can use html tags in the string. You can also use css.
`• <font size="3">${nm}   <a href =${link}>${name}</a>  ${yr}</font>`
