Sharing Web Map Extent and Layer Selection - Options?
1332
01-13-2021 10:53 AM
vblack
What are the solution that you can share with me?
We're a multidisciplinary team and i've created web apps to collaborate and share internally.  The teams want to be able to 'bookmark' the extent of their map and then send it to someone but ensuring that only particular layers that they want turned on are turned on and visible with that bookmark?
All the bookmark features (Enhanced Bookmark / ESRI bookmark) seem to either only save the spatial extent, or lack the capability to share with others? ...
Is there a way to do this?
Tags (3)
vblack
*WORKAROUND* i'm just going to leave this here as I figured a workaround solution. There is a widget for sharing and you can select "remember layer visibility" - so rather than sending the bookmark, you can send what you have as is.
