Select for Today in Arcade when data is in local time
1218
01-13-2023 03:25 PM
MeleKoneya
I published a feature layer to AGOL via ArcGIS pro and see in the data panel that our times are in local time which is what I wanted.
I am trying to grab only today's records using this:
var time = -1
var units = 'days'  //milliseconds, seconds, minutes, hours, days, months, years
var dateField = "Today"
var pastDate =  DateAdd(Date(), time, units)
if($feature.dispatch_date > pastDate)
  return dateField
The results are close to what I would expect 110 records, but it really should be 75.
I am guessing it is doing some UTC assumptions on my dates, but I am lost as to how to fake it to use the stored value which is local as far as I can tell since I published it that way.
Mele
JayantaPoddar
The following expression converts UTC date to to Local Date. Replace Timestamp() with your date variable.
ToLocal(Timestamp())
https://developers.arcgis.com/arcade/function-reference/date_functions/#tolocal
Think Location
MeleKoneya
I think I am getting closer to what I wanted.
I had to get just the date part of today.
2023-01-14T00:00:00-07:00 with the Text Function
var dispatch = $feature.dispatch_date
var Today = Date(Text(now, "Y-MM-DD"))
If (dispatch > Today)
  'today'
else
  'past'
Mele
JayantaPoddar
Assuming the dispatch_date field also has Date datatype, you can check the following expression
var dispatchdate = Concatenate(Year(dispatch),'-',Month(dispatch)+1,'-',Day(dispatch))
var currentdate = Concatenate(Year(Today()),'-',Month(Today())+1,'-',Day(Today()))
If (dispatchdate == currentdate)
  'today'
else
  'past'
Think Location
