Searching by layer, not seeing all of the fields
631
04-26-2024 01:23 PM
KentonSumpterMDA
Hi all,
In trying to make layers searchable I'm finding that not all of the fields are available as an option. Is there some reason not all fields are visible?
RussRoberts
Esri Notable Contributor
For a field to be searchable and, therefore, appear in the drop-down menu, it must contain strings or integers and not use a coded domain. Integer fields only support the Equals condition. For the best search results, choose a field with unique values.
https://doc.arcgis.com/en/arcgis-online/create-maps/configure-feature-search.htm
RussRoberts
KentonSumpterMDA
Thanks. It seems like a shortcoming that you can't search fields that use coded domains.
