Road Symbology and Labelling
242
2 weeks ago
SirivellaSuman
I am trying to add back the Interstate Symbology (was showing well until I changed the symbol color) on AGOL but I am not able to.
I wanted to know if this Webmap can be taken into ArcGIS Pro, add the symbol and bring it back to AGOL without disturbing the file names.
JamesPoeschel
Thanks for posting this question! I actually thought it wasn't possible, but after looking into it, I found out that it is.
You just bring the web map into pro, change the symbology, then right click on the layer, go to sharing, and select "Save Web Layer"
SirivellaSuman
When I try to get that webmap into pro. It downloads as a "ArcGIS Pro Portal Item" which does not allow changes. I tried to "Add Data" and Select the file from "My Organization," it shows only Feature Layers and not Webmap.
RussRoberts
Esri Notable Contributor
Can you share the symbols as a web style and then you can use them in Map Viewer?
SirivellaSuman
The only way is to recreate a webmap from ArcGIS Pro.
