Return HTML with Arcade in Pop-Up
2631
05-01-2023 08:05 AM
usace_sam_rd3
I have an arcade attribute expression that generates html.  I think I'm returning everything in the appropriate format, but my html is not getting interpreted.  What did I miss?
KenBuja
MVP Esteemed Contributor
Instead of using single quotes, use the back ticks. This is the template literal which allows you to use the "${}" placeholders.
return {
  type : "text",
  text : `<p>${fact_report}<br><a href="${fact_url}">Click to learn more</a></p>`
KenBuja
Instead of using that script in your Text element, you'll have to use an Arcade element to properly render that clickable link. You'll have everything above that in your Text element, the Arcade element for the link, then another Text element for the "Record last processed" information.
usace_sam_rd3
Ahhh!  I didn't even see that as an option!  However, I can't seem to get the variables returned.
fact_report & fact_url are variables upstream.  Is something missing in the return syntax?
return {
  type : "text",
  text : '<p>${fact_report}<br><a href="${fact_url}">Click to learn more</a></p>'
KenBuja
return {
  type : "text",
