Return a url based on a feature attribute in pop-up using Arcade?
2795
6
12-01-2022 02:03 PM
Hayley
I am trying to embed a URL into my pop-ups for a rubbish collection map.
If the collection week of a boundary is week one, I want the URL to go to the week one page.
If the collection week of a boundary is week two, I want the URL to go to the week two page.
I would like the URL to be embed into the word "here" in the pop-up as seen below:
What expression is needed to pass through the correct URL for each pop-up? I have started with what I have below but am aware URLs need to be formatted in a certain way. Any pointers much appreciated!
if ($feature.Week == "Week 1") {
    return "https://www.ashburtondc.govt.nz/?a=57072"
if ($feature.Week == "Week 2") {
    return "https://www.ashburtondc.govt.nz/?a=57073"
HL
Hayley
I found another way around it, using the expression below:
var calendarone = "https://www.ashburtondc.govt.nz/?a=57072"
var calendartwo = "https://www.ashburtondc.govt.nz/?a=57073"
if ($feature.Week == 'Week 1') {
    return calendarone
else {
    return calendartwo
HL
wayfaringrob
Honored Contributor
You'll want to add the Arcade as an attribute expression, and then point the hyperlink to that expression. It looks like you're using Map Viewer Classic, so that button is here:
Once you're there, try adding this expression:
var week = $feature.Week
decode(week, "Week 1", "https://www.ashburtondc.govt.nz/?a=57072", "Week 2", "https://www.ashburtondc.govt.nz/?a=57073")
Then, with "here" selected in your popup configuration, click Link and enter the name of your attribute expression in brackets, like this:
Click 'Update.'
Hayley
Hi @wayfaringrob thanks for your help!
I have created that as a new expression however am getting the error "Execution Error: Must have a default value result."
Am I missing something here? Thanks!
HL
Hayley
Hi again @wayfaringrob, I added the default value to the end of the expression and tested with no error.
decode(week, "Week 1", "https://www.ashburtondc.govt.nz/?a=57072", "Week 2", "https://www.ashburtondc.govt.nz/?a=57073", default)
The pop-up has recognised the word "here" as a hyperlink in the pop-up however it does not navigate to anywhere/can't be clicked. Am I missing something here? Thanks!
HL
Hayley
    return calendarone
else {
    return calendartwo
HL
wayfaringrob
Honored Contributor
Nice! Yeah, the Arcade documentation said the default portion was optional so I'm not sure why it didn't work that way.
Hayley
Thanks for your help @wayfaringrob 🙂
HL
