Restrict to Only Attribute Edits in ArcGIS Online map when source is feature service on your own server
3569
04-24-2016 08:17 AM
GregConiglio
Hello! I would like to restrict some users, using an ArcGIS Online web map, to only edit attributes, not feature geometry.  My feature service is from our own ArcGIS Server enterprise, not hosted on AGOL.  I see where this can be done with hosted services, but how can I do this when the source is SDE?
TobiasFimpel1
Greg,
you can log into your ArcGIS Server site's ArcGIS Server Manager Application and set the feature service's properties accordingly.
JayantaPoddar
MVP Alum
Disable "Allow Geometry Updates" under Feature Access capability in Service Editor.
Editor permissions for feature services—Documentation | ArcGIS for Server
Allow geometry updates allows users to edit the geometry of a feature in the feature service. This is enabled by default. If you disable this option, users will only be able to update the attributes of features in the feature service.
Think Location
TobiasFimpel1
Greg,
GregConiglio
Thanks, a perfect solution!
