Remove "Other" in Web Scene Legend
1110
07-06-2020 08:36 AM
BrianE
Why is AGOL generating an "Other" category in my scene legend if I don't have anything for "Other" (see screenshots below)?
How can I turn this off?
by Anonymous User
Not applicable
Hi Brian E‌,
As there is less ability to modify the legend in a web scene as opposed to a web map, you will need to toggle this off from your hosted feature layer's item details page. Select Visualization > then Change style > choose Options under Types (unique symbols):
Then toggle off the checkbox for 'Other' (shown above) > select OK > then Done > then Save the layer. Then when adding the layer to a web scene, 'Other' will be absent from the legend.
Hope this helps, let me know if there are any questions about this workflow.
-Peter
BrianE
I was told by someone at esri that this was a bug.
Also, what to do if I publish from a scene layer package and there is no feature class?
by Anonymous User
Not applicable
Brian E‌,
Thanks for the response. My mistake, I should have assumed you were working with a scene layer. You're right, this is a bug - I found the record internally. I logged it as BUG-000132826 so we can better track progress on it, and know when other customers run into it. If you would like to attach your account please email me at pklingman@esri.com with your customer number.
-Peter
