Related Tables in ArcGIS Online. Can I change the identifying field used to connect the related records?
2714
5
01-08-2018 12:37 PM
MichaelTorbett
Trying to create a feature service with related table in ArcGIS Online.
I've got some sql database data that has a lot of missing information in several records. In order to successfully create a relationship class that relates all records, I've had to create a new field that combines two existing fields in the attribute table. Now that all of my records are related correctly, I want to publish it to AGOL and use a different field to link the records for all new data going forward. Is this possible?
Michael
by Anonymous User
Not applicable
Is this data hosted on AGOL? Or is it being accessed via a service into AGOL?
I know the Migrate Relationship Class—Data Management toolbox | ArcGIS Desktop is useful in the DT environment. You can always overwrite the hosted FC with the migrated relationship class
MichaelTorbett
Hey Andrew,
Thank you for the reply. The feature service is a hosted on AGOL.
I've tried using the Migrate Relationship Class Tool, but unfortunately it only seems to work if you're using the Object ID as the key. I spoke with ESRI about it this morning and so far it seems that there isn't a way to change the key fields  in AGOL. I'm afraid what I may have to do is keep the current feature service as a read only archive (to maintain the current relationship)  and then publish a new service for new entry's going forward that will relate by global ID.
This data is ultimately going to be collected with Collector.
by Anonymous User
Not applicable
If the data isn't sensitive, I can take a look on my side and see if some Python can get us around this if you send it this way
MichaelTorbett
Hey Andrew,  a work around in Python would be great. Unfortunately the data is sensitive. We have a contract with the feds that prohibits me from sharing the information. When I have a little time, maybe I'll create some similar dummy data and send it to you. Thank you for the offer.
by Anonymous User
Not applicable
Classic feds and their sensitive data
I'll dedicate a few minutes to this and see what I can come up with
