Related data Pop-up configuration in ArcGIS Online-Map viewer
207
a month ago
PamelaPina
I have linked 3 related tables to my feature layer. All of my feature layer attribute data shows up on level one of the pop up, but I have to click into the related data to view the related information. Is there a way to configure the pop up so that the data for the related tables in not on another level, rather the pop up displays all the related data the same pop up level?
Tags (3)
CodyPatterson
MVP Regular Contributor
Hey @PamelaPina
Could you send a screenshot of the popup? This may just be because they are separated into different "Column" formats, so it shows up that they're different, instead, you may be able to create a Text entry, and then build your popup on just one level, something like this:
vs this:
https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/configure-pop-ups-custom-attribute-d...
Cody
EmilyGeo
Hi @PamelaPina, to pull in specific attributes from the related tables, you can set up arcade expressions. This video can help you get started https://www.youtube.com/watch?v=BWXZzYAIkKk
Ever wanted to click on an asset in a map and see data from its related table in the pop-up? Arcade makes this possible (and no you don't need to be an experienced programmer)! Here, we'll grab a simple code from the Esri Community, formally known as GeoNet, and walk through how to configure it ...
