RE: Trying to identify correct call to generate token to access feature layer
1762
08-02-2021 03:27 PM
GreggTurnbull
I am attempting to make a call against a FeatureLayer:
https://services.arcgis.com/4Y5FNypV9g2Wgf92/ArcGIS/rest/services/mobilehomes07232021/FeatureServer/...
I can generate a token using python:
import requests
tokenurl = "https://larimer.maps.arcgis.com/sharing/generateToken/"
data = {'f':'json','username':'username','password':'password','client':'referrer'}
r = requests.post(tokenurl, data=data)
return r.json()
When I attempt to make the service call above I get the 498, invalid token error.
I've tried this with token url set to our portal home (as above) and https://www.arcgis.com/sharing/generateToken. both tokens still fail to make the call.
Any help would be greatly appreciated.
by Anonymous User
Not applicable
Hi @GreggTurnbull - taking a second look it looks like you're missing the referer parameter from your data dictionary since you have client:referer. If you add 'referer: https://larimer.maps.arcgis.com' to data{} I expect this will work.
Also I think you may need to spell referer with one 'r' to specify the right parameter: https://developers.arcgis.com/rest/users-groups-and-items/generate-token.htm
-Peter
by Anonymous User
Not applicable
Hi @GreggTurnbull do you see the same result from https://www.arcgis.com/sharing/rest/generateToken - it looks like the /rest portion was omitted from the URLs.
-Peter
GreggTurnbull
Good morning Peter - It appears it works without the rest sub as well, but I reran the call:
https://www.arcgis.com/sharing/rest/generateToken/?f=json // along with credentials in the body, received an updated token,
Made the call:
And still receive:
"error" :
"code" : 498,
"message" : "Invalid token.",
"details" : [
"Invalid token."
Am I generating the token on the right server, I've tried: www.arcgis.com and our portal larimer.maps.arcgis.com.
Again thank you for the insights.
by Anonymous User
Not applicable
-Peter
GreggTurnbull
That was it Peter - did have one more hiccup as I had to remove the reference to client=requestip in the token generation step, client should be set to referer .. or omitted.
Cheers and Thank you!
