"The layer is not providing enough information to change the drawing style" Error Troubleshoot
12233
21
10-14-2016 10:39 AM
JennaMitchell1
I edited numeric values in the table of an existing layer on a ArcGIS Online map by editing the values through the pop-up windows. Since editing, however, I've been unable to change the layer style to show a different numeric attribute than currently displayed. Any time I attempt to change the displayed attribute, I receive the error, "The layer is not providing enough information to change the drawing style." Any suggestions for resolving this error? There are no typing errors that I can find (e.g., "," instead of ".", or letters instead of numbers). Here's the link to the map: http://arcg.is/2epbEFl
DanielMiranda1
I found a workaround! Switch to Map Viewer Classic, then set the symbol style for the polygon layer. It will allow you to use unique values based on your integer domain field. Then switch back to Map Viewer.
It is clearly some kind of bug with Map Viewer that based on this thread, has been around for years.
by Anonymous User
Not applicable
Hi Drew,
I have sent you a direct message, I think this would be best handled through a Support case.
Katie
RowenaTansley1
I am receiving this same message when I try to create a heat map Portal 10.5. Any suggestions?
Thanks.
by Anonymous User
Not applicable
Hi Rowena,
If you have access to Technical Support I suggest creating a case so we can investigate this error further and document the results.
Thank you,
Katie
EastRIU
Can anyone provide me with a fix for this, too?
I'm trying to create a heat map with a dataset in ArcGIS Online, but when I try and reduce the area of influence, it comes up with the error message the original poster stated at the top of this thread.
Any help very, very much appreciated.
by Anonymous User
Not applicable
Do you have access to Support? If so please open a case for this issue. If you do not have access to Support please let me know.
CraigBeebe01
Has this issue been resolved?  I have been attempting to do the 'FieldMaps' tutorial and keep receiving the message related to polygons.  My points and lines are set up exactly the same way and have no issue.
JoshuaLogsdon1
Same issue here following that tutorial. It's happening in the new map viewer.
GISWisDom
I am now also receiving this same error when I try to classify a data which which was previously not classified. No access to support as it is limited to one person in my university organisation.
Help required
LindseySmith5
I am also receiving this message when I go to manipulate style of displaying city population data in a basic map.   Should I go directly to the contact person at our institution?
