"Failed to add data" error when trying to use BLM National PLSS Map Image Layer?
1164
12-08-2021 07:39 AM
AndyGarcia1
I've been working with this file for a long time and not too long ago, it kept asking me to repair the data connection but when I try to do it, I get the error shown in the image I attached. I'm thinking it's an issue with the server the file is hosted on? But figured I'd ask on here just in case. I know AWS went down so I assumed maybe it was associated with that but I don't know for sure. Thank you for any replies.
jcarlson
What about re-adding the service to your map, rather than repairing the data source? I am able to use map service without issue.
- Josh Carlson
Kendall County GIS
AndyGarcia1
Tried that as well. Deleted the service, saved the file and relaunched, then attempted to add it again and still getting the same error. I can add other data fine but most PLSS layers I try and add just give me the same error.
