Publishing Time in ArcGIS Online
469
03-21-2019 07:28 AM
AlexanderFischer
New Contributor III
I use a very simple, lightweight shapefile. Publishing it sometimes takes 20 seconds, sometimes takes 10 minutes, sometimes takes forever. Changing the settings of a feature service also takes a lot of time, more than half an hour! I never had such issues before. Has there been any change in ArcGIS Online recently? What could be the problem?
JacobLias1
Have you tried clearing your browser cache or trying a different browser altogether?  I'd say start out with the browser cache and see if that resolves the issue.  If the issue persists we can continue with some other troubleshooting steps.
-Jake
KellyGerrow
Esri Frequent Contributor
Are you using Chrome? if so, which version?
Check out this blog about a potential bug in chrome and some workarounds.
https://community.esri.com/people/ARex-esristaff/blog/2019/03/12/why-cant-i-use-the-add-item-dialog-...
-Kelly
AlexanderFischer
New Contributor III
Hi, I was using the REST API.
Publish Item—ArcGIS REST API: Users, groups, and content | ArcGIS for Developers
The problem seems to be gone today although I haven't changed anything in my source code. Is there anything that I can do if I come across the same problem again?
KellyGerrow
I would suggest getting in contact with technical support if you come across the same problem. Tech support can look into your specific issue to determine what is occurring.
-Kelly
