I use a very simple, lightweight shapefile. Publishing it sometimes takes 20 seconds, sometimes takes 10 minutes, sometimes takes forever. Changing the settings of a feature service also takes a lot of time, more than half an hour! I never had such issues before. Has there been any change in ArcGIS Online recently? What could be the problem?
Have you tried clearing your browser cache or trying a different browser altogether? I'd say start out with the browser cache and see if that resolves the issue. If the issue persists we can continue with some other troubleshooting steps.
-Jake
Are you using Chrome? if so, which version?
Check out this blog about a potential bug in chrome and some workarounds.
-Kelly
Hi, I was using the REST API.
Publish Item—ArcGIS REST API: Users, groups, and content | ArcGIS for Developers
The problem seems to be gone today although I haven't changed anything in my source code. Is there anything that I can do if I come across the same problem again?
I would suggest getting in contact with technical support if you come across the same problem. Tech support can look into your specific issue to determine what is occurring.
-Kelly
