Publishing flattening out curves in data
1042
02-19-2013 08:01 AM
MaryEllen_Perko
Hello.  I'm hoping someone can shed some light on this problem we're having when publishing to AGOL through ArcMap 10.1.
The data in the .mxd looks like this:
[ATTACH=CONFIG]21948[/ATTACH]
The same data in AGOL looks like this:
[ATTACH=CONFIG]21949[/ATTACH]
Does anyone know why this is happening.  Any help is greatly appreciated.
Thanks.
by Anonymous User
Not applicable
Original User: mikem
Are those "true curves" I think they're called? Where the data is defined as an arc. If so, hosted feature services don't support that. It is on our enhancement list, however.
Mike
MaryEllen_Perko
Thanks for the quick response.  And they probably are "true curves."  It's good to know it is not something on our end. Hope this enhancement is at the top of the list :).
Thanks again.
MaryEllen_Perko
Hi.  I have a quick follow-up question, and it may be a stupid question... But, if we generate a tiled map service using AGOL's computing resources, would we see the same thing?
by Anonymous User
Not applicable
I believe it should work with tiled map services. I suggest trying a small test area to be sure...
Mike
