Hi all
I am wanting to publish a PNG image as a tile layer to be used in a map but not as a basemap, I want to keep the Topographic basemap and switch the PNG tile visibility on/off. Ideally without consuming any credits.
From ArcGIS Pro I have tried publishing the image as a Tile Layer with caching locally but when I add the tile to the Map Viewer in AGOL the only option is to have it as a basemap. The tile package is fairly small size (45mb with levels of detail street to county)
Is there something that I am doing wrong or an alternative process I'm not aware of?
Thank you!
In Map Viewer, make sure you select the Layers icon, then select Add:
Once you find the published tile layer, you can click the + Add button:
which should add it as a data layer, not a basemap.
Or, you can click on the tile layer itself and choose where to add it:
This will add it to the layers and can be moved above/below other layers, and toggled on/off:
R_
@abrown8 I am experiencing the same issue. My Tile Layer is defaulting to the basemap even though I simply click "Add to map" and not "Use as basemap".
@KevinFreibergerJA I did manage in the end, I think it was when publishing from ArcPro to check what the coordinate system of the raster is and ensuring that you set the tiling mechanism to ArcGIS Online.
I'm having the same issue. I reprojected the raster layer to EPSG 3857 to match ArcGIS Online, but the layer only gets used as a basemap. If I have a basemap open, then add my raster to map, not as a basemap, the basemap disappears, and I actually lose all basemap options to add.
This is happening to me as well, even though I'm following the same workflow of adding a Tile Layer I used a month ago where it worked fine, it's now adding it as a Basemap. I've tried different combinations of how to add a layer to a web map, but am wondering if this may be a bug.
