Public Maps Gallery template version 1.4  --Opening post
39191
175
11-22-2011 02:57 PM
Esriwebmap
Please reply to this opening post to submit questions and comments about the Public Maps Gallery (PMG) template version 1.4.
PtomHarner
Thanks for the info Matt - do you know the status of the update?
ElizabethLahey
I used the code changes you suggested and it fixed the issue for our v1.4 gallery. Thanks Matt!
PtomHarner
We are running v1.4 but not the latest version released in early December. As a result, there is not a layout.js file.
Is there a different procedure for previous versions?
Thanks.
ElizabethLahey
We don't have the new version with a layout.js file either - the code for older versions is located in scripts\home\local.js.
MattDriscoll
Here's a app that you can use to remove the url parameter from your webmaps. Log in and fix any webmap that has a url property.
http://servicesbeta.esri.com/demos/urlfix.html
The url property shouldn't be added anymore when editing webmaps.
PtomHarner
Thanks Matt, that utility works great.
