Public Maps Gallery template version 1.4  --Opening post
39388
175
11-22-2011 02:57 PM
Esriwebmap
Please reply to this opening post to submit questions and comments about the Public Maps Gallery (PMG) template version 1.4.
MattDriscoll
[ATTACH=CONFIG]12362[/ATTACH]I have attached 2 of the config files and a screenshot of the message.
Hey David,
I dropped those files in and it ran fine for me. It didn't ask for a group ID.
DavidAlford1
I have no clue....still gives me the same message. After I clicked OK, it sends me to the ESRI Group ID page.[ATTACH=CONFIG]12369[/ATTACH]
Hey David,
TarigAhmed1
Glad that worked 😄
Ok. I'm having the same IE spining problem.
Would you please take a look at this if you have a min.
http://maps.mckinneytexas.org/MapsGallery1.4/index.html
Thanks in advance for your help.
Tarig
MattDriscoll
Tarig
Hey Tarig,
Were you able to fix it? I looked using chrome and IE and everything seemed to be loading correctly.
Parish_ofAscension
In PMGT, is it possible to show attributes from multiple feature classes (parcels, school district, city limits) in the same pop-up window, when the user clicks on the map? Map is created using .MSD file utilizing data from SDE and published through ArcGIS server & PMGT.
If yes, Is it controlled by the Identify tool options in .MSD file?
Thanks in Advance.
VJ.
MiguelParedes
Greetings from Esri UK, PMG team and forum folk,
I was wondering if it would be possible to access additional groups from the right side pane?
It would make a great addition to the gallery, since one would be able to access related groups to the opening (main) one. Would you consider such an implementation for future versions?
Many thanks and cheers for now.
Miguel
MichaelKlein
Thanks in Advance.
VJ.
Hi VJ.  I've used the Chrome - Identify template to show attributes from multiple feature classes.  You might check out the Chrome - Identify template.
Esriwebmap
I'll see if we can implement that. It sounds like a useful feature. Thanks for the feedback!
LeslieZolman1
I have the 1.3 template customized and set up but would like to add the new legend features.  Is there any easy way to add them to 1.3?
Esriwebmap
Hi Leslie,
Unfortunately, the 1.3 can't just be upgraded. You'll have to download the 1.4 version and configure it. It's much easier to configure 1.4 though.
