Problems/error while adding WFS layers (from Geoserver) in ArcGIS Online
3748
5
05-01-2024 11:56 PM
robbiesailo
I have published several shapefile layers on my Geoserver account which I intend to use it on ArcGIS Online. I am facing issues/problems while adding them as a New Item in my ArcGIS Online Content.
1. I clicked New Item in the Content section, selected the URL option and entered the WFS link of my Geoserver. The Type section is automatically set to "WFS (OGC".
2. I click Next and this gives a list of WFS layers that I had published in my Geoserver account with an option (radio button) to choose which WFS layer I want to add. I select the layer to add by clicking on the radio button next to the layer I want to add.
3. Adding the first WFS layer in this list is possible. (Bulk adding of WFS layer is not possible, so have to repeat the steps of adding layers)
4. When I repeat the step of adding items like above, only the first item in the list gets added. The subsequent WFS layers in the list (even though I have selected to add) does not get saved, instead the First layer on the list gets saved.
For example:
1) The first WFS layer in the list is Drainage. This gets added successfully.
2) The next layer after Drainage is Land use.
3) I select this Land use layer (clicking on the radio button next to the Land use layer) and click next. Give the WFS layer an Item name to add to ArcGIS online content, Descriptions, Tags, etc, and then Click Save
4) The WFS layer that I had just saved should the Land Use but when viewed in Map Viewer, it is actually the Drainage layer (which happens to be the first layer in the list of WFS while adding the content through URL option).
On the flip side, when I add the same WFS layer from within the Map Viewer -> Add layer from URL -> Enter the url link/address and select the specific WFS layer from the radio buttoned list, The specific layer that I choose gets added to the Map.
In my opinion, I think this is a bug with ArcGIS Online and should be fixed if there is no work-around for it.
Or If there was something that I missed during the process, please let me know.
Your support and guidance would be of much help as I intend to use Geoserver and WFS services for database storage/service and ArcGIS Online as the front-end application.
Robert Sailo
Tags (3)
bbollin
hi @robbiesailo, can you please send me the WFS you are working with?
robbiesailo
https://office.sailogeosolutions.in/geoserver/JVT/wfs
My Server is online during the office working hours in India, So if you get any connection error other that what I have raised here, that means my server must be switched off
JokevanLinge
I am experiencing the exact same issue. Unfortunately the WFS I am using is behind authentication that I cannot share with you.
I follow the same steps but have something extra to report: when adding it from the Content --> add item the layer (even though the wrong layer) has the correct order of attributes with correctly set up decimals etc.
If I do this from the map viewer, the layer somehow has all attributes in alphabetical order with incorrect options for decimals. This workaround would therefore mean I have to redo all attributes and the order to be able to showcase it correctly.
This seems like a bug to me too.
JokevanLinge
 Some additional information is:
I am using a geoserver service (tried OWS WFS), within ArcGIS Enterprise Portal version 11.3.0.
The URL I am using (which is missing the authkey so therefore not working) is https://<domain>.<domain>.nl/geoserver/user_ws/ows?SERVICE=WFS&REQUEST=GetCapabilities&VERSION=2.0.0...
Is there already a bug for this specific item? If it exists I wish to be included or kept up to date of this bug. I have a client who does not want to upgrade their ArcGIS Enterprise Portal until this bug is fixed; when it is fixed they would like to know so they can plan an upgrade.
PeterHodkinson
For reference this issue was recognised as a bug which was fixed for ArcGIS Online and at Portal for ArcGIS 11.5
