Problem with Creator etc. fields after updating AGOL hosted feature layer
1786
09-23-2022 02:39 AM
AdminWPZ
Hi all,
I'm using an AGOL hosted feature layer and several views of it in an Instant App and in AGOL Field Maps with online and offline data collection. I also collected Creator and Editor information.
At one point I had to export the layer from AGOL into ArcGIS Pro to update some Contingent Values and Field Groups. I kept the Creator etc. information and used "overwrite existing service" to publish the data to the same service.
Instead of using the existing Creator columns, AGOL created new ones (Creator_1 etc.):
Is there any way to avoid this problem and at the same time keep the existing Creator etc. information?
Richard_Purkis
@AdminWPZ Have you tried following this support article? The last few steps cover preserving the editor tracking fields when overwriting:
Let me know if this helps
Richard_Purkis
AdminWPZ
Hi Richard, thank you so much for the link. This has worked out perfectly. I wasn't aware that you can edit Tracking fields by hand after disabling Editor Tracking.
One question: step1 of the list (copy feature layer) seems futile to me as the copy isn't used later. Is there a reason to do this step?
Thanks again!
Andrea
Richard_Purkis
@AdminWPZ  Not all the steps in the article apply in your scenario. In the article, the feature class is edited in step 10. I understand in your scenario you already exported the data so it was just the steps at the end of the article you needed to follow.
Hope that helps
