Power automate update geometry using Lat and Lon
917
09-12-2025 07:26 AM
vijaybadugu
I Published a Hosted feature service  using query layer with Lat and Lons from non spatial database  on to the ArcGIS Online. I just wanted to create a Power Automate, if some thing changes in non spatial database like lat and long, it should update the feature layer without writing a new python script to update that hosted feature service.
I guess, it is possible to update through arcgis online connector in Power automate. Could some one help us to solve this issue?
VenkataKondepati
Honored Contributor
Here’s a minimal, working pattern (no Python needed):
Flow outline (text key or GlobalID)
Trigger (pick one):
  • SQL Server / PostgreSQL row change trigger (premium) — fires on update
  • or a Scheduled flow that queries rows changed since last run (using a LastModified column)
Steps:
  1. Get changed row (must include a unique key and lat, lon).
    • Prefer a stable key (e.g., AssetID). Don’t use OBJECTID.
    • If you can store the feature’s GlobalID in the DB, even better.
  2. ArcGIS Online → Update a record in a feature layer
    • Where clause (string key):
      AssetID = '@{triggerOutputs()?['body/AssetID']}'
      (If numeric: no quotes.)
      Or, if you stored it:
      GlobalID = '@{triggerOutputs()?['body/FeatureGlobalID']}'
    • Attributes: map fields you want to update (e.g., Status, Notes, etc.)
    • Geometry (point):
      { "x": @{triggerOutputs()?['body/lon']}, "y": @{triggerOutputs()?['body/lat']}, "spatialReference": { "wkid": 4326 } }
      (If your layer is in Web Mercator 3857/102100, either send 4326 and let the service project, or pre-project before sending.)
  3. (Optional) Upsert logic
    • If the update returns 0 records affected, call Create a record in a feature layer with the same attributes + geometry (i.e., insert when missing).
Gotchas to avoid
  • OBJECTID is not stable → don’t match on it. Use a real business key or store the GlobalID back to your DB when you first create features.
  • Ensure lat/lon are not null; skip the update if either is blank.
  • If many rows change at once, switch to Update records in a feature layer (batch) and pass a WHERE like AssetID IN ('A1','A2',...), or loop with concurrency 1–5 to avoid throttling.
  • Keep the field names identical between your DB and the feature layer (or map them carefully in Attributes).
Quick start field plan
  • In your DB table: AssetID (unique), lat, lon, Status, LastModified
  • In the hosted feature layer: same fields + GlobalID (enabled)
  • (Optional) Store the feature’s GlobalID back to your DB on first insert to make future updates bulletproof.
If you share your actual key/field names (and the layer’s WKID), I’ll give you the exact WHERE line and the Geometry JSON you can paste into the Power Automate action.
Regards,
Venkat
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
vijaybadugu
Thanks . How do I update lat and Lon for a feature class in geodatabase ? Do we need to publish as feature layer to update ?
gis_KIWI4
MVP Regular Contributor
@vijaybadugu - That's the easier option. PowerAutomate can update feature layers.
I don't think there is any action within PowerAuotmate to update GDB directly unless you want to update the SQL DB directly. I would advise against the direct DB updates as they bypass the tracking and any attribute rules, etc.
