Possible to find out where feature layers are being used in web applications?
37301
54
02-09-2022 08:12 AM
ZachRobinson_SantaClaraCounty
I am wondering if it is possible to easily find out which web applications in our ArcGIS Online organization are using a specific feature layer.
For example, if I delete a layer from our organization, I want to make sure I know which web maps and applications the deletion will affect. This can be difficult and tedious to search manually when an organization has many web maps and applications.
EmmaCurran18
@jcarlson I am getting the same error as @HaThach1 . Have we found a solution to this? I haven't been able to get something to work.
WesleyMills
I know this is an older post I found it yesterday and had the same problem as you. Izk222 already bypassed the issue with a different technique but for this specific script:
The issue is that you need to run the same 'for loop' for web maps as you do the web apps. "matches" only contains a string of id numbers for the maps. It doesn't have a title, id, or type. Running the loop captures that data to send to the pandas data frame.
From the top for catching apps and web maps:
from arcgis.gis import GIS
import pandas as pd
# Log in to portal; prompts for PW automatically
gis = GIS('your portal url including https', 'your username')
# Layer ID to search for and its URL
find_id = 'layer id number'
find_url = gis.content.get(find_id).url
print(find_url)
# Pull list of all web maps in portal
webmaps = gis.content.search('', item_type='Web Map', max_items=-1)
# Return subset of map IDs which contain the service URL we're looking for
m_matches = [m.id for m in webmaps if str(m.get_data()).find(find_url) > -1]
# print web map ids that use this layer for sanity check
for i in m_matches:
    print(i)
# create list to store target maps
map_list = []
for w in webmaps: # for every map in your portal
    try:
        # Get the JSON as a string
        wdata = str(w.get_data())
        criteria = [
            wdata.find(find_url) > -1, # Check if URL is directly referenced
            any([wdata.find(i) > -1 for i in matches]) # Check if any matching maps are in app
        # If layer is referenced directly or indirectly, append app to list
        if any(criteria):
            map_list.append(w)
    # Some apps don't have data, so we'll just skip them if they throw a TypeError
    except:
        continue
# Pull list of all web apps in portal
webapps = gis.content.search('', item_type='Application', max_items=-1)
app_matches = [a.id for a in webapps if str(a.get_data()).find(find_url) > -1]
# print web app ids that use this layer for sanity check
for i in app_matches:
    print(i)
# Create empty list to populate with results
app_list = []
# Check each web app for matches
for w in webapps:
    try:
        criteria = [
        if any(criteria):
            app_list.append(w)
    except:
        continue
# display data
print('apps:')
pd.DataFrame([{'title':a.title, 'id':a.id, 'type':a.type} for a in app_list])
# display data
print('web maps:')
pd.DataFrame([{'title':m.title, 'id':m.id, 'type':m.type} for m in map_list])
Jaime_Carlino
Hey Wesley, thank you for compiling bits from previous posts and putting them together here. This seems to be working well for web maps, but I am not getting any output for web apps. I am using service layer IDs that I know are used in web maps that were then used in applications like a dashboard. I appreciated the sanity checks for both web maps and web apps, which was my first indication that something is going on with the web apps. Any insight?
GITTeam
MDB_GIS
Hey,
Just curious, but how long should it take this tool to run? We have a fairly small AGOL org with less than 500 items but the tool has been running for about 15 minutes so far. This  is my second attempt at running it.
I'm running it in the Python window and it appears to be running, but it is just bogged down somewhere.
MDB_GIS
Replying to myself in case anyone else has the same issue as we finally figured it out by writing in a debug line that lists the layers it is currently scanning.
In the past, we had created a few applications using AppStudio, which has since been abandoned by ESRI. They are classified as a "Native Application," so they get lumped in with the "Application" filter. We added a specific filter that skips these items when scanning. Once I did that, the script worked flawlessly. Here is our version of the script.
awgeezrick
Thanks for sharing Josh. Came in massively handy for me today.
LesleyHope
Hi, this may be a stupid question but I've been going round in circles for what feels like days - where am I putting this code?
Lesley
WesleyMills
You can run it into arcgis notebooks. In pro: click analysis on the top ribbon, click the drop down arrow for python toward the top left of the ribbon, click python notebook.
NavaSheer
Is there any other way to do this without Python or other coding?  I am not a developer but really need this tool.  Geo Jobe offers it in Pro for a fee, but would appreciate if ESRI would offer for free!
