Possible to find out where feature layers are being used in web applications?
36203
51
02-09-2022 08:12 AM
ZachRobinson_SantaClaraCounty
I am wondering if it is possible to easily find out which web applications in our ArcGIS Online organization are using a specific feature layer.
For example, if I delete a layer from our organization, I want to make sure I know which web maps and applications the deletion will affect. This can be difficult and tedious to search manually when an organization has many web maps and applications.
jcarlson
MVP Esteemed Contributor
@Katie_Clark, you guess right: you can do this with the Python API!
The text version:
  1. For a given layer's URL
  2. Find all maps that reference that layer
  3. Fina all apps that reference those maps or the layers directly
The tricky part is # 3. An app can reference a layer directly in one of its widgets, like the Search widget. Other apps, like Experience Builder and Dashboards, can also reference layers directly without going through a map. Further complicating this is that certain apps will make direct references to a layer using their ID, rather than their URL.
To make sure our search is comprehensive we can't just search for the apps that reference the maps; we'll have to search for the layers directly as well. It gets a bit convoluted, but it works!
The code:
from arcgis.gis import GIS
import pandas as pd
# Log in to portal; prompts for PW automatically
gis = GIS('your-portal-url', 'username')
# Layer ID to search for and its URL
find_id = 'a405b06ae8e24f94a2768a4581b79e73'
find_url = gis.content.get(find_id).url
# Pull list of all web maps in portal
webmaps = gis.content.search('', item_type='Web Map', max_items=-1)
# Return subset of map IDs which contain the service URL we're looking for
matches = [m.id for m in webmaps if str(m.get_data()).find(find_url) > -1]
# Pull list of all web apps in portal
webapps = gis.content.search('', item_type='Application', max_items=-1)
# Create empty list to populate with results
app_list = []
# Check each web app for matches
for w in webapps:
    try:
        # Get the JSON as a string
        wdata = str(w.get_data())
        criteria = [
            wdata.find(find_url) > -1, # Check if URL is directly referenced
            any([wdata.find(i) > -1 for i in matches]) # Check if any matching maps are in app
        # If layer is referenced directly or indirectly, append app to list
        if any(criteria):
            app_list.append(w)
    # Some apps don't have data, so we'll just skip them if they throw a TypeError
    except:
        continue
pd.DataFrame([{'title':a.title, 'id':a.id, 'type':a.type} for a in app_list])
The output DataFrame will be any apps that reference your layer:
You can easily amend the final line of the expression to include additional details about the items.
- Josh Carlson
Kendall County GIS
Katie_Clark
I would love to know if this is possible as well! As far as I know there isn't an "easy" solution, but maybe something can be done with the Python API?
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
MichaelVolz
Have you considered looking at 3rd party vendor solutions designed specifically for this issue?  I would look at GeoJobe especially if this is a time consuming task for GIS personnel at your org as AGOL and Portal mature and there is a good deal of content.
Katie_Clark
I think I've looked into GeoJobe before....correct me if I'm wrong, but it is not a free service, correct? It would be difficult to justify the expense to higher management (non-GIS) who would have to approve something like that, unfortunately.
Best,
Katie
jcarlson
The text version:
The code:
import pandas as pd
app_list = []
for w in webapps:
    try:
        criteria = [
        if any(criteria):
            app_list.append(w)
    except:
        continue
- Josh Carlson
Kendall County GIS
Katie_Clark
Thank you, Josh! I'll definitely look into this.
Best,
Katie
Fantastic, thank you so much for your thorough response!
NickShannon2
This is great! Thank you.
Can the script be modified to include 'web maps' in the output DataFrame?
jcarlson
Of course! Since our list of maps is already defined earlier, that last line could just be amended like so:
pd.DataFrame([{'title':a.title, 'id':a.id, 'type':a.type} for a in matches])
If you want the maps together with the apps in the output, you can just use the pandas method concat:
dependencies = pd.concat(
        pd.DataFrame([{'title':a.title, 'id':a.id, 'type':a.type, 'url':f'{gis.url}/home/item.html?id={a.id}'} for a in app_list]),
        pd.DataFrame([{'title':m.title, 'id':m.id, 'type':m.type, 'url':f'{gis.url}/home/item.html?id={m.id}'} for m in matches])
But if the properties you want from the maps / apps are the same, you could also just merge the two lists together:
all_items = app_list + matches
pd.DataFrame([{'title':a.title, 'id':a.id, 'type':a.type, 'url':f'{gis.url}/home/item.html?id={a.id}'} for a in all_items])
- Josh Carlson
Kendall County GIS
HaThach1
Hi, I implement this script above to include the maps together with the apps but got an error for m in matches section.
Have any idea? thx
