Portal and MS Office
3771
04-28-2014 08:20 AM
StephenCoppola
Good Afternoon:
Question 1: Can Portal be configured to search Geo-referenced data from MS Word, PowerPoint, etc. ?
Question 2: If Yes, is there a standard format that the MS Word, PowerPoint, etc, has to be in?
Thank you for your time and suggestions
StephenCoppola
Crafty762
Your time and insight is greatly appreciated.  This information answers these questions.  Please feel free to mark this forum as checked.
Thank you for your time.
WilliamCraft
Good Afternoon:
I am a bit confused by your first question.  What do you mean by "search Geo-referenced data"?  Are you asking if Portal can include MS Office documents in its search results just as with geographic content or are you asking if Portal can literally search inside an MS Office document stored in Portal or are you asking something else?  Generally speaking, users can upload and share MS Office documents from within Portal.  This section of the Esri help discusses that functionality a bit.
I'm also confused by your second question.  What do you mean by "standard format"?
On the other hand, you might be asking if users can search Portal's geographic content from within MS Office applications.  If that's the case, then the answer is 'yes, somewhat'.  Esri Maps for Office loosely integrates MS Excel and MS PowerPoint with Portal for ArcGIS in that you can create maps from shared content on Portal or uploaded content.  This functionality is not available in MS Word.
StephenCoppola
Thank you for your reply and suggestions, here's some further clearification
With respect to Question 1: The latter, does Portal have the capability to parse inside a Word document for geographic names, lat/lons, addresses, etc.?
With respect to Question 2: When hosting a Word doc on Portal, is there a way to tag the document so it can be searched by keyword or geographic extent?
Your time and suggestions are appreciated.
WilliamCraft
Thanks very much for clarifying.  Regarding question 1, I believe the answer is 'no'.  Searching Portal for content will only return a result set based on specific details about the document such as owner, title, type, description, etc.  In other words, Portal cannot scan inside of a document to find a string or parse it as you described.  Regarding question 2, yes absolutely... in fact, tags are one of the best things you can do with your content because it allows you to associate keywords which helps to facilitate Portal's search functionality.  Creating tags can be accomplished through Item Details for a particular document, map, layer, etc. that you have uploaded to Portal.  Clicking the Edit button within the Item Details section allows you edit the title, summary, thumbnail image, description, access and use constraints, tags, credits, and extent.  You can add tags to Items and to Groups.
Let me know if this answers your question, and if so, please mark the correct answer with the green check to the right of this post.
StephenCoppola
Crafty762
WilliamCraft
You need to move the green check next to MY post not yours.  Could you do that please?
