Popup Windows in Story Maps
563
06-25-2020 09:22 AM
Institute_forPublic_Strategies
I have two layers on a map embedded in a story map - a point layer and a polygon layer.
If I click on a POINT in my map, the popup window renders information associated with the POLYGON layer.
But then you can click on the arrow at the bottom of the window and pull up the information for the point layer:
Ideally, I would rather have two separate popup windows for each of the layers, or at the very least, have the point layer show up as "1 of 2" and the polygon "2 of 2." In the original web map, the point layer is on top of the polygon layer. Any suggestions?
