Popup link in attribute expression go back to my webmap
656
12-13-2022 02:08 PM
TimHayes3
Two of the 3 links in my popup work fine and go to the website in the var link, until I click on a point that references 'Type IV'. When I click on any point in my webmap that is Type IV, the link goes to my webmap.
if ($feature.RESOURCETYPE == "Type II (500 - 1,999 persons)")
{return link = 'Type II';}
if ($feature.RESOURCETYPE == "Type III (250 - 499 persons)")
{return link = 'Type III';}
If ($feature.RESOURCETYPE == "Type IV (249 or fewer persons)")
{return link = 'Type IV';}
Any ideas on why this is happening? I queried and double checked that  "Type IV (249 or fewer persons)" is correct in the attribute table.
jcarlson
MVP Esteemed Contributor
I don't see how that expression returns the URL. Is it link += 'Type'? Reading your expression, those conditions would result in link being overwritten.
Also, when you're just mapping a single attribute to different outputs, you could use Decode instead.
var t = Decode($feature.RESOURCETYPE,
    'Type II (500 - 1,999 persons)', 'Type II',
    'Type III (250 - 499 persons)', 'Type III',
    'Type IV (249 or fewer persons)', 'Type IV',
If (!IsEmpty(t)){
    return `your-url/${t}`
} else {
    return 'no link'
- Josh Carlson
Kendall County GIS
TimHayes3
Decode works better, thank you. But, 'no link' shows up in my popup as a link to my webmap. Any thoughts on how to ensure it is text and not a Link?
jcarlson
Where exactly is this being used? Is the map public? I can't really tell why it would behave this way without more context.
- Josh Carlson
Kendall County GIS
TimHayes3
The map is not public. I modified your code a tad bit:
    'Type II (500 - 1,999 persons)', 'Type II (500 - 1,999 persons)',
    'Type III (250 - 499 persons)', 'Type III (250 - 499 persons)',
    'Type IV (249 or fewer persons)', 'Type IV (249 or fewer persons)',
If ($feature.RESOURCETYPE != "TBD - Leave Blank"){
    return link = t
} else {
    return 'no link'
Here is what it looks like with 'no link' in the popup:
Here is what the Text box has:
