Pop-ups not working in Map Viewer
27672
65
04-20-2023 09:18 AM
Triflight
I have a web map created in ArcGIS Online where the pop-ups for one of the layers does not work. When clicked on, instead of the pop-up popping up nothing happens. The other layers on the map have their pop-ups working correctly.
The problem layer in question has pop-ups turned on and they are custom configured to display a select number of fields & it uses an Arcade expression for the title.
When using the map in the Field Maps mobile app and selecting a feature from this layer, the custom configured pop-up works and can be viewed. When viewing the map in Map Viewer Classic, the custom configured pop-up works and can be viewed. When viewing the map in Experience Builder using the map widget, the issue persists and the pop-ups do not work.
I am truly unsure why Map Viewer refuses to display pop-ups for this single layer, any assistance would be greatly appreciated.
sosero
by Esri Contributor
@kawakawa4 ,
We suggest you log a Support case and share the web map so that we can Investigate further.
OliviaHarrison
We've just run into this problem ourselves. We're going to try rebuild/recreate the layer to see if that fixes it, but would be very happy if there was a fix.
AspenN
I started facing this issue today in a web map in Portal for Enterprise 11.2. I have a point feature class that works with popups and one that doesn't (even though the preview works when configuring popups). Both had a picture marker symbol for the symbology. I tried updating the symbol for the one that wasn't working to an svg and it still doesn't work. I also significantly increased the size of the point symbol with still no success. Is it possible that the bug that was fixed in the June 2023 release of ArcGIS Online is still an issue in 11.2?
AllisonLehn1
I'm also getting this issue after publishing a layer with pop-ups configured in ArcGIS Pro as a web layer, and unfortunately none of the solutions mentioned here have fixed it. I published the layer referencing registered data as a Map Image layer with Feature Layer (but with editing disabled, as it is not possible for my layer):
The pop-ups work for the Map Image layer in both Map Viewer and Map Viewer Classic, but only work in Map Viewer Classic for the Feature Layer. I also tried publishing the layer as a copy of the data (so a hosted Feature Layer):
This did work on both Map Viewer and Map Viewer Classic, but for my purposes, I need the data to be referencing the registered data store. Any suggestions?
AllisonLehn1
Update on this: I've gotten this to work if I do one of two things:
  1. Register the view with the geodatabase
  2. Rewrite the query in ArcGIS Pro when adding data as a query layer. So, instead of SELECT field1, field2, field3 FROM view_name, I write the query that formed the layer in the first place, joining the original data tables.
The core of the issue might be that some of the tables I'm joining in my views are not part of a geodatabase. This was fine for Map Viewer Classic, but my guess is that there are some new restrictions with this when it comes to Map Viewer. If there is ever a conclusive answer on this, I would appreciate a tag!
AndresCastillo
MVP Alum
This was the case for me.
I was using a db view, and the popup would not work when clicking on the features.
I registered it with the geodatabase, and overwrote the service, and the popups worked again.
dhochhal
I just upgrade from 11.0 to 11.1 today. I noticed in the first map I tried, that attachments don't seem to have the link in field maps, Map Viewer Classic gets no popups and Mapviewer seems to be working fine. I've only just tried this on one map so far. Another fact of note, is that this map is available through a collaboration with arcgisonline. I turned off sync for the collaboration before upgrading. The popups still work when viewing the map in either map viewer from arcgisonline in a browser, I guess the attachments haven't been working in field maps even prior to this upgrade because that is where I first viewed the map and that is from arcgisonline version. So the popup issue appears to be different than the attachments in the popup issue. I recently upgraded to Pro 3.2 from 3.1 prior to this and had to revert back to 3.1 because all kinds of bugs with 3.2, from python scripts not working to not being able to access lyrx files. Anyway, ESRI you really need to slow up on the version upgrades and get things working before you release more software IMO.
dhochhal
Update to this post!
I cleared the browser cache, cookies, etc. and popups as well as attachment links started working in both map viewers! Pretty simple fix, but I stand by the statement about slowing up the version changes until everything works, or just more quality checking maybe.
MK13
@RussRoberts  @EmilyGeo @bbollin  Any idea on how to get pop-ups to work in map viewer for polygon layers published with a transparent fill and dashed outline? Currently pop-ups only work when one clicks on the outline.
bbollin
@MK13 Can you provide more information? I can click a transparent /dashed outline polygon in the middle and the popup opens fine.
