Pop Up Chart Config w Two Arcade Variables in Single Chart?
1004
09-04-2018 08:12 PM
johnmosheim1
Pop Up Window Configuration with two simple Arcade expressions - trying to show two new variables in a single chart in pop up window chart. I tried having both the diesel and the electr formula in the same Arcade Expression but only one chart shows up. Then I separated them and still did not work - there are two separate charts in the same pop up window.
Any thoughts?
What I did (have a similar one for elec)
What I'm getting:
XanderBakker
Esri Esteemed Contributor
What you need to do is to create a single chart with the two fields based on the Arcade expression (sorry for the Spanish interface):
This will show like this in the pop-up:
johnmosheim1
Thanks a ton!
JM
XanderBakker
You're welcome. Don't forget to mark the question as answered using the  button at the post that answered your question.
