Performing a Join Field Between 2 Feature Class Lists Using ArcPy
2587
02-16-2023 07:50 AM
KedaravindanBhaskar
Hi all, hope you are well,
I am trying to perform a join field between two lists of feature classes using a for loop. Currently I am joining each item in the list with the corresponding item in another list individually. Here is a snippet of code -
#Creating list of points. Splitting into groups of 1 & 2
SamplePoints1 = ["PT1_points_DirWestLines", "PT1_points_DirSouthLines", "PT1_points_DirEastLines", "PT1_points_DirNorthLines"]
SamplePoints2 = ["PT2_points_DirWestLines", "PT2_points_DirSouthLines", "PT2_points_DirEastLines", "PT2_points_DirNorthLines"]
AllPoints = ["SamplePoints1","SamplePoints2"]
#Altering to preserve info on which group the point came from
for points2 in SamplePoints2:
    arcpy.management.AlterField(points2, "Elevation", "Elevation_2", "Elevation_2", "FLOAT", 4, "NULLABLE", "DO_NOT_CLEAR")
#Joining back both point lists
###Here is where I am facing challenges
arcpy.management.JoinField("PT1_points_DirNorthLines", "OBJECTID", "PT2_points_DirNorthLines", "OBJECTID", None, "USE_FM", 'Elevation_2 "Elevation_2" true true false 4 Float 0 0,First,#,PT2_points_DirEastLines,Elevation_2,-1,-1')
arcpy.management.JoinField("PT1_points_DirEastLines", "OBJECTID", "PT2_points_DirEastLines", "OBJECTID", None, "USE_FM", 'Elevation_2 "Elevation_2" true true false 4 Float 0 0,First,#,PT2_points_DirEastLines,Elevation_2,-1,-1')
arcpy.management.JoinField("PT1_points_DirSouthLines", "OBJECTID", "PT2_points_DirSouthLines", "OBJECTID", None, "USE_FM", 'Elevation_2 "Elevation_2" true true false 4 Float 0 0,First,#,PT2_points_DirEastLines,Elevation_2,-1,-1')
arcpy.management.JoinField("PT1_points_DirWestLines", "OBJECTID", "PT2_points_DirWestLines", "OBJECTID", None, "USE_FM", 'Elevation_2 "Elevation_2" true true false 4 Float 0 0,First,#,PT2_points_DirEastLines,Elevation_2,-1,-1')
 Here's the Syntax for the join field tool -
arcpy.management.JoinField(in_data, in_field, join_table, join_field, {fields}, {fm_option}, {field_mapping})
Is there a method to achieve the join field as lists or do I have to do each individually? Any help is appreciated. Please let me know if there is anything else you need to assist me.
Regards, Kedar
Tags (3)
DanPatterson
MVP Esteemed Contributor
if the lists are paired as they appear to be, you can zip and save a line or two... assuming everything works as you have posted.
joins = list(zip(SamplePoints1, SamplePoints2))
joins
[('PT1_points_DirWestLines', 'PT2_points_DirWestLines'),
 ('PT1_points_DirSouthLines', 'PT2_points_DirSouthLines'),
 ('PT1_points_DirEastLines', 'PT2_points_DirEastLines'),
 ('PT1_points_DirNorthLines', 'PT2_points_DirNorthLines')]
for i in joins:
    arcpy.management.JoinField(i[0], "OBJECTID", i[1], ....etc)
... sort of retired...
DanPatterson
joins
for i in joins:
KedaravindanBhaskar
Hi Dan,
This worked perfectly. Thanks.
Just for reference here is the complete code for the code starting in line 13
for i in joins:
    arcpy.management.JoinField(i[0], "OBJECTID", i[1], "OBJECTID",None, "USE_FM", 'Elevation_2 "Elevation_2" true true false 4 Float 0 0,First,#,PT2_points_DirEastLines,Elevation_2,-1,-1')
Regards, Kedar
