online geojson file to auto update?
1385
03-25-2023 11:13 AM
StephenEarl
Hi all
I have a geojson file i host on a web hosting service. This file is then updated every minute using a python program.
Can i add a link to the data to be used on a Web Map? I know i can add the file via link as a feature layer but it just loads the data but does not update.
I have a student version of Arcgis so i don't have access to enterprise features.
ShaunWalbridge
Where will you be using the layer? If you're working with the JavaScript API, you should be able to add it directly with https://developers.arcgis.com/javascript/latest/sample-code/layers-geojson/. If you'd like to use it more generally across products (e.g. add it to Pro), you might be better served by getting a free account from https://developers.arcgis.com/ and adding it as a normal feature service. You could do this with e.g. the Python API, and then you can just plug into the other systems which well understand feature services.
