Offset line symbology with Arcade?
1980
11-30-2021 01:39 PM
I_AM_ERROR
I have a feature service that is road lines. I'd like to offset the lines using Arcade in AGOL without actually modifying the data. Is this feasible?
I see in the expression builder there is an offset function for geometry. How do I actually call the geometry and return it as an offset? Only examples I'm finding is using arcade to return string values which you can then symbolize on. Can you draw the geometry in a different location?
Tags (3)
I_AM_ERROR
reading about arcade profiles, I'm going to guess the answer is no...
JayantaPoddar
Could you test this?
If you have ArcGIS Pro, you could add a symbol effect "Offset" to the hosted feature layer, and save it.
Use symbol effects—ArcGIS Pro | Documentation
Think Location
I_AM_ERROR
tested with no luck. I don't think symbology in pro carries forward to AGOL with the exception of basics like color, etc.
