no resource
3609
6
04-10-2016 08:35 PM
maherelayyan2
No resource could be found at that address when trying to add WMS image service in Arcmap 10.2.2
AdrianWelsh
MVP Honored Contributor
Hi Maher,
Is it possible for you to share the link to the WMS here?
AdrianWelsh
Are you sure that you have the correct URL? Can you contact anyone at that agency to verify that the URL is correct? Or maybe the service is temporarily down (or maybe the service has changed)?
maherelayyan2
The same error massage for many , maybe the service link changed from LPI or it is not working  ??
AdrianWelsh
It sounds like you may need to contact the organization to see if the link is incorrect or if the service is down.
JayantaPoddar
You could use the following URL (it asks for authentication)
http://mapsq.six.nsw.gov.au/arcgis/services/Imagery/LPIMapIS/ImageServer/WMSServer?request=GetCapabi...
The REST URL that I found is as follows
Imagery/LPIMapIS (ImageServer)
Think Location
