Newly Added Features Disappearing in AGOL
3364
07-21-2014 08:33 AM
LeahFitzgerald1
I am finding that new features (geometry) that I'm trying to add to my map in AGOL disappears as soon as I finish drawing it. I was able to add features the other day but could not edit them. I am new to AGOL and cannot figure out what I'm missing. This map and data is mine, I am the crator and administrator.
Any thoughts or help would be greatly appreciated.
Tags (3)
DonOpgenorth
I've
moved your post into the
Web GIS  space. You will get a much better answer here as the GeoNet Help is intended for community help and feedback. I have also added in a few additional tags. You can see more
on the community structure, and what topics are under each space from the
following documents:
GeoNet Community Structure
ArcGIS Discussion Forums Migration Strategy
Thanks!
Don
DivyamGulati
Hello Leah,
Are you using ArcGIS Server Feature Service in ArcGIS.com webmap or is it an ArcGIS.com hosted feature service?
A good test would be to consume your service in any other client you are familiar with.. For example a Flexviewer application. If its an ArcGIS Server FS then it might be related to some sort of a permission issue over the Database. In that scenario you might want to try and publish another feature class as a FS service on ArcGIS Server and then try and edit it through ArcGIS.com.
